-   Pantera (https://www.offshoreonly.com/forums/pantera-39/)
-   -   28 with Black hawks (https://www.offshoreonly.com/forums/pantera/357863-28-black-hawks.html)
bigboat28 11-27-2018 06:28 PM
28 with Black hawks
Would Black hawks work on a 28?
Brandon Anderson 12-18-2018 09:34 PM
My 28 with extension box needs a drive spacer to prevent blowing out and easier to plane off
Twin O/B Sonic 12-19-2018 05:30 PM
I would think they'd act similar to surface drives and youd loose some of the props ability to carry the bow.
Never thought of this until hearing it from a friend that had, I believe a 27' Pachanga w/surface drives. I think it was a bit faster than w/Bravos but the hull ran more wet.
And yeah if you had raised X dimensions, youd probably struggle to come on plane.
Tinkerer 12-19-2018 06:37 PM
Blackhawk drives work best on a hull that naturally carries the bow or has a built in rocker at the transom.
bigboat28 12-20-2018 08:32 AM
Isn't that a Pantera hull. Always thought they were built to try to carry the bow?
onesickpantera 01-09-2019 04:13 PM
According to Jo the 28 does have some rocker built into it .
