Correct x-dim and prop
hey guys, im just tryng to learn about this prop thing and x-dim, Im running a 3 blade 25 pitch Quicksilver mirage LH prop and im getting 68 on gps speedo at 53-5400 rpms, this is in fresh water, I heard that the quicksilver props are not that good and they are different that the regular mercury mirage but it seems that i should be a little faster than that. I measured the bottom of the boat to the bravo housing and its exactly 8 1/2 inches. Different boats require different dims, I hope i can get this boat over 70. I want to know what you guys with 24s are running and specially the x-dim .
thanks for the info. Forgot, the motor is a 502 435 hp. |
When I hit the water, I'll let you know. :(
You have a 20% slip from the math table, you want to be at around 10% max. The X-dimisions on the 24 are all set at 17. Good luck;)
Pantera 28, i have no idea how to measure to get the number you have, the only thing I know its that from the bottom of the boat to the bottom of the house measures 8 1/2 inches. I wonder what my number is.
You have to bring your outdrive all the way down, get a straight pole and measure from the bottom of the v bottom to the center of the prop shaft.
call me at 305.882.7000 ext 3201 and I will guide you to it. Albert |
Thanks for the offer Albert, boat in the shop right now getting carpet in the cabin put in. Will have it back in a couple of days. I want to find out what the x should be before i start messing with props. Let me say im glad i got a pantera, the thing i was concerned with before i bought anothe boat was the handling on the rough, with wife and kids, and this boat its just awesome, of course now i want to go faster but i dont want to touch the engine since i promised my wife(bad mistake). But im sure you guys will help me with that, thanks for the info and the help.
Carlos |
Carlos where do you launch your boat. If you dont plan to race then leave it alone, it will cost you an arm and a leg to get mph. Just a thaught to keep in mind, try to get the most out of it with what you got before you open the can of worms.;)
Albert |
Chances are that your tach is reading a little high and I think the 24 will run better with a rh prop if you have a bravo drive and can try it.
well, i sent the prop to throttle up which was supposed to be a 25 and it is a 23, no wonder i was turning that many rpms, they made it a 24 and added cup, I think all 24s are running a 25 or higher when they have over 400 hp, hope to try it this weekend and see some difference.
| All times are GMT -5. The time now is 05:20 PM. |
