Fuel pick up....in tank??? Twin engine 28 >
Old 04-12-2004, 09:31 AM
Performance Boat Center
Tim G.'s Avatar
Question Fuel pick up....in tank??? Twin engine 28
Mainly for Jo/Pepe, but I'd like anyone's experience to pay off here..
-Both engines were hard to start.
-Changed fuel filters. They had collected alot of water/rust/etc.
-Engines started right up..
-Ran for 1 hour from Haulover to Sundays on Key Biscayne. Ate lunch. Port engine would not light. Starboard took three attempts but did start.
-Idled out on one engine.
-Headed north.
-Port engine started after about 1/2 hour...
-Got home. Starboard engine ran on the flusher. Port engine only ran for 2 minutes.
I have not taken the fitlers back off...but to block up in 1 hour is quite unusual.
I'm thinking I have "stuff" in the tank that is getting on the fuel pickups and clogging them. The rocking/rolling as we were idling on one engine may have cleaned the port pickup enough to get it going...
Are the fuel pickups under the cap that is on the floor under the back seat? Can the pickups be cleaned out effectively, or do I need to replace them?
I've obviously never taken them apart before. Am I opening a can of worms???
What seals the cap/access on the tank when I reassemble?
I'm hoping to get this squared away by next weekend's Miami SBI race... I'm scheduled as a turn boat...
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 04-12-2004, 02:29 PM
BRUCE SEROFF's Avatar
Tim,
Im not sure about your boat, but my pick ups appear to be welded to the tank and cannot be removed. They are about 1/2" off the floor of the tank.
the pickups are located under the bench seat. If you remove the fuel level sender assembly, you can look into the tank with a flash light and view the pick ups.
Hows your fuel pressure? Are you running electric or mechanical pumps? If electric, you may have some debris in the screens. maybe you have restrictions somewhere else in the lines.
BRUCE SEROFF is offline
Old 04-12-2004, 02:47 PM
Tim G.'s Avatar
Bruce,
I just spoke to Jo and Pepe...
Yeah, I'm going to check the filters again, than look at the screens on the pumps.
The engines are 502MPis... Small electric pumps mounted on the lower left of the engine..where only a small Oriental guy could possibly reach. But I'm thinking those screens are blocked as well, so I don't have much of a choice but to get down in there....
I don't have pressure gauges... It would be nice to have them...
I'll pull the gauge out of the tank and have a look...while breathing very deeply and smoking a cigarette...
Coming down for SBI Miami?
Tim Gallagher
[email protected]
954-809-8739
Tim G. is offline
Old 04-12-2004, 02:52 PM
I will be in Miami sometime on Friday.
Old 04-12-2004, 03:01 PM
Tim G.'s Avatar
Racing?????
Tim Gallagher
[email protected]
954-809-8739
Tim G. is offline
Old 04-12-2004, 03:06 PM
yes sir
Old 04-12-2004, 06:27 PM
Hi Tim,
I saw you coming in through Haulover, I was at the sandbar....that boat looks real nice, limping or not....good luck with the fix
thedonz is offline
Old 04-12-2004, 07:26 PM
TURBOED's Avatar
where are the pits to the race going to be and where can you see the race from?
TURBOED is offline
Old 04-12-2004, 07:29 PM
http://www.superboat.com/calendar/miami/miamiinfo.html
srlbrodkin
5
10-03-2007 01:11 PM
dhlaw
Cigarette
11
02-27-2006 07:15 AM
fastlane40
Eliminator
12-15-2005 09:38 AM
yikes
09-15-2005 07:40 AM
JROMY
07-23-2003 07:29 AM
Quick Reply: Fuel pick up....in tank??? Twin engine 28
