Bridge clearance for a 28 single??
Ok, I looked at the specs on the sight, saw a 22" draft but no mention of height in the water.
Anybody know the height say with 100 gallons and 400 lbs of people. yeah, the lake is up and the bridge is tight, 54" is what I have right now or I put it on a trailer to go to the north side of the lake (where all my friends hang out) Thanks, Cat |
I'm not sure exactly, but I'd say you'll be real close.
looks like your the test pilot..let us know how it goes :D..don't scratch my baby though!
Move to the other side of the tracks....problem solved. :p
I'll just loan you some of my fat girlfriends to help weight it down for the journey to the north end of the lake. Buck |
Let the lift down and backed off, looks like 48" at the center of the windscreen, less 400 lbs of people, going to go for it, will confirm later. 6" should be enough margin, I've got buds that've done it with 3-4". Besides, if i have to shower reverse it'll bring the nose down anyway:D
Which is it- balls of steel or stupidity??:p |
Made it!!
Did you have to use the fat chicks?:p
NFCA!!!!!
| All times are GMT -5. The time now is 05:11 AM. |
