What props work best on a 34 ?
Bravo. Hydro, 4 or 5 blade. I have a set of imco 1 in shortys I want to put on and im not sure what prop works best. Even if the 1 inch is to much ill put in a spacer . I think the imco designed lower should be faster than a standard bravo style plus they are large shaft.
Erase some msgs. or call me at 978 479 3636
Brian |
Sorry didn't know it was full. Send away!!
i used a set of 30 6 blades boat road amazing have 2inch shorties with its boxes on mine with hp 500 boat did 92 cruise speed at 4000 rpm is 70
Im running a high x from the factory and 1 in imco shortys and my engines make 509 at 5100 rpm. . With stock out of the box 34 4 blade bravo,s I run 90.3 At 4800 rpms on a 90 deg. day in a 1 ft chop. I Just got my props back from BBlades and I havent had time to try them yet.
How did your new props work out ?
90mph at 5k rpms. going to send them back and have them loosend up a bit.
Understood
