-   Powerplay (https://www.offshoreonly.com/forums/powerplay-52/)
-   -   33PP Dead Battery Experience (https://www.offshoreonly.com/forums/powerplay/139713-33pp-dead-battery-experience.html)
ActiveFun 09-05-2006 10:38 PM
For all of us that were wondering about opening the engine hatch with a dead batter, I experienced the problem this past weekend. I went to open the engine hatch to turn on the batteries and nothing. I connected alligator clips from Radio Shack to one of those portable jump starter. I connected the possitive to a terminal on the back of the circuit breaker board and the negative to the ground buss bar where all the grounds are connected. Its on the opposite side than the circuit breaker board kinda on the gunwale. It worked fine. After all that I thought of another idea. I was wondering if connecting my battery tender from my car in the garage, to the cigarette lighter in the cabin would give the circuit panel voltage. I'll try that if it happens again.
I'm still wondering what the problem was. All the switches were off and nothing was left on. I'm hoping it was just a bad battery since both batteries were replaced at the beginning of this season. Someone told me there is circuit breaker switch under the rear seat starboard side. Anyone switch that off??
Indy 09-06-2006 06:47 AM
Re: 33PP Dead Battery Experience
I have three switches underneath my bench seat but have no idea what those are. Anybody? Ed?
Good idea on the circuit breaker panel, being in construction, I always have a 12v drill, saw or something around that I'll use if that ever comes up.
BTW...The starboard switch should be on 1 and the port on 2, not sure if you knew that or not.
JROMY 09-06-2006 07:30 AM
I've got 2 switches under my rear seat that disable the engine hatch buttons. Not sure if they control anything else.
ActiveFun 09-06-2006 08:56 AM
That is exactly how I have been setting the battery switchesm and then both on off when I get back to the marina. If the auto bilge is not running, what would have drained that battery? and which battery is the hatch connected to when the switches are off?
baja27 09-06-2006 09:27 AM
If your bat dies all you need is a 12 volt source and two jumper wires. Attach them to your up push button for your hatch. Then push the button the hatch opens and then you can access your batteries.
trader1 09-06-2006 10:46 AM
I would recomend purchacing a jump pack. I have one and it has really come in handy.
ActiveFun 09-06-2006 08:23 PM
Exactly. FYI, you don't have to exactly connect them to the up button, you can connect to any red wire behind the circuit breakers, they are all daisy chained together.
MACTIME 09-07-2006 04:37 PM
My 28 powerplay hatch has a access hole cut in it, under the removable sun pad. The hole is secured with a screw-in access cap. The hatch lift is attached by a bolt that has a cotter pin through it for easy disconnect.
OSO 09-07-2006 09:52 PM
they kill all power, standard issue on a powerplay.
