-   Powerplay (https://www.offshoreonly.com/forums/powerplay-52/)
-   -   Power trim lines (https://www.offshoreonly.com/forums/powerplay/188553-power-trim-lines.html)
Goin Nuts 06-09-2008 01:34 PM
Power trim lines
Can anyone tell me where to get the steel braided power trim lines
Elite Marine 06-09-2008 06:24 PM
We can get the plastic coated Parker ones in any length you need with straight or 90 ends. These are what is standard in most boats.
[email protected]
Kirk
Ed 06-10-2008 10:54 AM
PowerPlay Trim Hoses/Lines...
Hi Mark...The long steel-braid trim lines can be bought from: Henry's Engineering, 170 Bugeye Square, Princefrederick, MD., 20678-4113, Phone number: 410-535-3142 Ask for Henry or Pam Martin. Great quality, great service, at a great price. Anything else I can do, let me know. ;)
Goin Nuts 06-10-2008 04:29 PM
Thanks again ED
one other question the top part of my eao switches are sticking not the switch or the lamp its the very top part any idea on a part # it not the 704.900.5 or 704.950.0 or the 704.950.5 can't find it on the eao web site call them they want me to send a pic
Ed 06-11-2008 11:35 AM
EAO PushButton Switches
The answer to sticking EAO push-button switches is this: There are two small switch adjustment screws under the panel on the switches "mounting flange", that hold the switch square in the panel hole. They both must be adjusted exactly equally, or the housing pinches the plunger sleeve, distorting its shape, and thus their movement. Their other enemy is just plain grit in the sleeves. Hope this helps.
brj 08-26-2008 02:57 PM
Would like to talk to the Ed that used to work for powerplay. Can you help me find this person? I have question about the hull of PP 33.
thanks
Ed 08-27-2008 07:35 AM
thanks
Here I am, ask away...:)
brj 08-27-2008 03:46 PM
have a questions about 33 pp. Trying find somebody that knows factory specs for attaching deck to hull for a 33 sport deck and best route to match those specs re-attaching deck to hull. [email protected]
thanks for answering!
Powerplay25 08-27-2008 10:03 PM
Contact Steve 1 on this forum. He knows the Powerplay hulls quite well.
If he cannot answer your question, he'll point you in the right direction.
DareDevil 08-27-2008 11:26 PM
The Deck is set over the hull with the lip on the deck , put some epoxy putty in between it and clamp it down .
Then screw it toghether and class 2-3 layers of fiberglass inside. (stripes,.....start with 6 ,then 9, then 12 inch wide)
atach rubrail ,done.
Atleast, thats how mine was.
