-   Powerplay (https://www.offshoreonly.com/forums/powerplay-52/)
-   -   25 Powerplay OB, what are the best props? (https://www.offshoreonly.com/forums/powerplay/277931-25-powerplay-ob-what-best-props.html)
Brad 06-04-2012 12:39 PM
I recently bought a 91 25 Powerplay with 200 Optimax's and 24 Chopper props. I'm on the rev limiter at 65, what are the best props for this boat?
Brad
Brad 06-06-2012 03:43 PM
Brad
After a little more testing I thnik I'm not gettijng enough oil to the engine and that is what I'm hearing nor tev limiter!
illMATTic 07-20-2012 10:36 AM
Did you ever get this figured out? I am just curious. I am looking for a similar setup.
Brad 07-23-2012 08:25 AM
No still battling optimax problems, plan is to send the props to get them changed to 25 or 26 over the winter.
Powerplay25 08-02-2012 10:49 AM
Choppers will get you the best top end. For all around running I like my Bravo's that were reworked by BBlades. Better crusing, easier to get on plane and decent top end.
kds 08-02-2012 04:12 PM
Originally Posted by powerplay25 (Post 3744408)
choppers will get you the best top end. For all around running i like my bravo's that were reworked by bblades. Better crusing, easier to get on plane and decent top end.
what size and diameter bravos were u running powerplay 25 ? I am trying to get some 28 bravos , the 14 1/2 diameter not the 15 1/4 diameter. They are hard to find.
Powerplay25 08-02-2012 11:20 PM
I ran 15 1/4's. They were 26's. Had BBlades blueprint and turn them to 27's. They were perfect for my 225's.
