-   Powerplay (https://www.offshoreonly.com/forums/powerplay-52/)
-   -   Ed, 38' Transom Angle? (https://www.offshoreonly.com/forums/powerplay/278182-ed-38-transom-angle.html)
DEFYN GRAVITY 06-07-2012 12:38 PM
Ed, Do you remember the transon angle on the 38's? I think it is 10 degrees? Looking to install standoff boxes and want to make sure the transon will accommodate it, Thanks, Robbie
BTW, How ya been?
Ed 06-19-2012 05:23 PM
38 PowerPlay Transom Angle...
BTW, How ya been?
Hey Robbie...Just stay'n busy, or I'd got nutz, lol. Did you find out the angle you needed? I believe it was 13 degree's, but check it with an angle finder, that you can buy cheap enough at Sears Tool Dept. Blue skies...;)
DEFYN GRAVITY 06-20-2012 05:22 PM
Ed, Thank You for getting back with me. Great to hear you are staying busy!!!! Stay out of trouble!!! I have used a cheap angle finder, I come out at 10 degrees, looking at putting boxes on the back, was told the 38' did not have a standard angle transom. News to me!!!! I also need several EAO switches, you still know where I can get them? I plan on getting down your way soon, Lunch? I will give you a call let you know, Blue Skies, Robbie
rchevelle71 06-21-2012 07:22 AM
Place a carpenter's square with the long side ( 22 1/2" ) against the keel. When the short side ( 14" ) comes in contact with the transom, take the measurement ( see the sketch below ) between the inside corner of the square and the boat bottom. Each 1/4" is equal to 1 degree in slope of the transom.
http://www.seamount-mattson.com/trandiag.htm
DEFYN GRAVITY 06-21-2012 06:39 PM
Thank you for the info & the drawing, I have never seen this method before. I will try it when I get home on Sat, again, thanks, Robbie
rchevelle71 06-22-2012 06:44 AM
No problem, I also forget how to do it every time and have to look it up, this method was originally taught to me by the guy that made my outboard bracket, and I have used it for several since then.
