-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   Installing a dual bank battery charger (https://www.offshoreonly.com/forums/powerquest/100181-installing-dual-bank-battery-charger.html)
cbgenrl 04-07-2005 11:00 PM
I have a 29 Enticer with the camper package (fridge and micro). As best I can tell I do not have a battery charger on the boat. I want to run the fridge all summer as the boat is lift kept (with shore power) and there is nothing like a cold one waiting for you on the dock :drink: .
Does anybody have the same setup? Does the fridge run off of the showerpower when plugged in? My guess is it does not and therefore want to install a battery charger (wouldn't mine having one regardless).
Has anybody installed one of these? I assume I need to wire the charger into the AC/DC fuse panel and the shore power will feed it from there? Any recommendations on chargers?
-Wally
boatnt 04-08-2005 06:54 AM
Re: Installing a dual bank battery charger
On my boat when I plug in the shore power it runs the refrigerator, at the same time I can also turn the battery charger on and charge the batteries and run my 12v accessories
cbgenrl 04-09-2005 09:03 AM
NT, where is your charger located? I was looking in the engine compartment for one, no luck.
Do you keep the fridge on at all times while it is on the lift?
Nice avatar.......
boatnt 04-09-2005 09:46 AM
Nice avatar.......
The charger is bolted on the drivers side rear bulkhead on the engine compartment.
I do keep the fridge on while on the lift.
