-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   260 Legend 7.4 Mpi Prop? (https://www.offshoreonly.com/forums/powerquest/102650-260-legend-7-4-mpi-prop.html)
HOTTZU98 05-07-2005 07:31 PM
CAN ANYONE WITH A 280 LEGEND WITH A 7.4MPI(310HP0 TELL ME WHAT PROP THEY RUN? bOAT HAD NO PROP WHEN I GOT IT. Have a 21 mirage plus on and it needs more rpm like 300-350 more rpm. Thanks!!
Fast Forward 05-08-2005 07:41 AM
Re: 260 Legend 7.4 Mpi Prop?
I've got a 97 Legend with a 454 Mag EFI and I'm spinning a 23p Mirage Plus. Are you sure its not a mag???
boatnt 05-08-2005 11:35 AM
max rpm on a 7.4mpi should be 4600rpm if you have a 21 and your are turning 4300rpm at wide open throttle then you need to go down to a 19 pitch and that should bring the rpms up about 200 to 250 .
before you do that make sure the throttle linkage is adjusted right and its opening the throttle plate all the way.
good luck
HOTTZU98 05-08-2005 03:09 PM
somebody said go to a cupped 19 to get it to about a 20p any sense in that? the merc prop slecto says a 20.6 is ideal pitch?
boatnt 05-08-2005 09:01 PM
If you get a 19 mirage plus it will be cupped.
I'm not a prop pro but from what I have heard the difference between a mirage and a mirage plus is that the mirage plus is cupped.
Fast Forward 05-09-2005 06:42 AM
Check on Ebay you should be able to pick one up between $150 to $250.
And boatnt you are correct on the Mirage Plus it is cupped v.s. the standard is not.
