Help with bunks on a 29 Enticer
If anyone with an Enticer could take a measurement on there trailer bunks (inside) I would really appreciate it. Spent a couple hrs trying to get the boat to sit right. No 100% sure I like where it is located. Its on a hoist, so when I bring it up I want it to fall into place.
Thanks |
Re: Help with bunks on a 29 Enticer
1 Attachment(s)
Rick does this help?
Tom |
boatnt
My bunks are set more like this. What do you think? There more vertical. Do you have a picture of your trailer bunks? I'm eventually going to purchase a trailer. Thanks |
Let me take a pic of my trailer when I go down to pull the plate off it. Unfortunately, I don't have a pic of mine on the trailer.
1 Attachment(s)
Rick
bunks are under the outer lifting strakes. click on the picture you should be able to see it. |
This really isn't a reply to your question. But i do have a question maybe you could help me out. I have a 1999 29 Enticer with 310 7.4 mpi twins it does around 65+ mph I need some feedback on installing supercharges on the engines. Some people told me the 29 doesn't like speeds over 70mph, so supercharging is a waist of my time? If this is true?How can i make the 29 handle better @ 70 + mph? Is it possible. By the way i have a Manning dual axle 10000lb bunk trailer with the boat on it now if you need pics. Thank for listening. Paxtonsc
Boatnt,
I see you have 4 blades on your boat what engines do you have and what size 4 blades. I have 310 7.4 mpi's and am looking to put 4 blades on mine. Right now i have 3 blade bravo's 25 pitch. Paxtonsc |
Originally Posted by paxtonsc
Boatnt,
I see you have 4 blades on your boat what engines do you have and what size 4 blades. I have 310 7.4 mpi's and am looking to put 4 blades on mine. Right now i have 3 blade bravo's 25 pitch. Paxtonsc i have bravo 1 26 pitch 4 blades |
Originally Posted by boatnt
have the same set up as you
I had the 25 mirage plus 3 blades,the boat did about 66.5 on gps and was at about 4550 rpms.
with the bravo 1 -4 blades the boat runs at about 4450 rpm and 65mph on gps. again thats with 1/4 of a tank or 3/4 of a tank and 2 or 6 people ,weight doesn't seem to make a difference. but the boat handles so much better with the 4 blades. I have my 3 blades in the garage now for about 3 years collecting dust. |
| All times are GMT -5. The time now is 02:12 AM. |
