-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   props, spinning in or out??? (https://www.offshoreonly.com/forums/powerquest/119191-props-spinning-out.html)
powerquest 380 12-27-2005 03:32 PM
Has anyone out there done any testing with props spinning in or out? Im told that if there spinning in thats faster with poor handling at slow speeds (docking), spinning out is a bit slower but way better at the dock. My 38 spins in now and she is a bear at the dock, but I dont want to give up any speed :rolleyes:
And if I do this how do you do it? If I switch props Im assuming I need to put her in reverse to go forward, right :eek: Then if I like it, do you switch sides with the drives or what?
jmackin 12-27-2005 03:47 PM
Re: props, spinning in or out???
Stepped boat? If so hull was designed to have bravo 1 props spinning in to achieve best bow lift. Switch props and just remember reverse is forward if you wanna try it. I tried it on my 99 I had.
Dave98 12-27-2005 04:46 PM
PQ 380,
Mine are spinning in on my 300 Revenge. I tested some labbed props late last season and during the testing we turned them out. Lost about 1 to 1 1/2 mph. Had a great rooster tail though. Macklin is right, the trannies are backward.
Scott 12-27-2005 06:38 PM
Just what do you know :rolleyes:
Kidding Mary still misses you!
I have also tried this lost speed and threw a huge tail! The only positive out of it was that I looked good docking.
One suggestion around the docks that will help is to have the drives all the way down and keep the tabs down half way the boat will track a lot straighter :cool:
Mentalpause 12-27-2005 07:17 PM
What Mackin said - try it and let us know what the outcome is. Mine spun out, I wanted to try them spinning in but never got around to it. I would like to hear from others how it impacts getting around at the docks. Do you basically go back to docking like you did with a single engine boat?
jmackin 12-28-2005 05:19 PM
As long as your better 1/2 is w/ you you'll look cool docking.
I'm bored and feel like causing trouble. :cool:
powerquest 380 12-28-2005 06:30 PM
Im also told she wont bow steer as much when turning out too. Any truth there? So where are you guys going if PQ is totaly gone :eek: Sunsation 43, cig Top Gun, or a beak????
PWRQWST 12-28-2005 06:36 PM
Oh god no beek please :D , I will look at the 43 Sun, 42 Tiger, or a 43 Nor Tech :drink:
Mentalpause 12-28-2005 07:18 PM
So is the additional stern lift from rotating in pushing the bow down? Hopefully you can compensate with trim.
Just get the Cig - you know that is what you want :drink: :drink:
