-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   34' Vyper Hull Question (https://www.offshoreonly.com/forums/powerquest/159699-34-vyper-hull-question.html)
rrentsch 05-31-2007 03:40 PM
Back by the transom, on both sides just above the tie down u- bolts there are 2 approx. 1 1/2" dia. ring with rubber flappers in them. They look like they could be drain valves, but I noticed that at times they are under water at anchor and could let water run into the bilge if they didn't close. Does anybody know what they are there for ? I can see rust streaks on the inside of the boat
rrentsch 05-31-2007 03:46 PM
1 Attachment(s)
Here is a picture
Vyper340 05-31-2007 08:55 PM
In 2002 they got rid of those as they were drain holes that were not required.
Fast Forward 05-31-2007 09:11 PM
Looks like a drain for the molded swim platform.
cjrents 06-15-2007 10:51 AM
After looking more into this, your best bet is to probably just sell the boat to your son for $10k and you can by a brand spankin' new pontoon.
C M R 06-15-2007 01:19 PM
Our old 34 Vyper (2001) had that also. That's what I figured they were for is to drain the water in the swim plat form.
Macklin 06-16-2007 07:12 AM
As a matter of fact they got rid of them between the time they built BillR's boat and my boat in late '01. :cool:
pkspx 06-16-2007 08:39 AM
Its like a baffle drain for the swim platform, Seadoo Jetboats use to have these. Another analogy would be external flaps on exhaust tips. Lets water out but not it, It really does look like and I always worried that it was going to take on water but never failed.
wwwTOPDJcom 03-31-2021 10:22 AM
My 2002 has them
My HIN is 02 and it has them 92D102 is the last numbers on my hin 92nd vyper built
