Temperature Gauge Question
Our Temperature Gauge In Our 1996 24ft Powerquest Precept Does Not Work Anymore. My Question Is How Do You Fix It.
Thanks In Advance Todd |
the temp sender is located by the thermostat houshing.
unplug the wire from the sender and ground the wire,the gauge should go to hot,if it does then you need a new sender,if it does not move then you either have a wire or a guage problem. |
| All times are GMT -5. The time now is 04:42 PM. |
