-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   top speed 280 silencer?? (https://www.offshoreonly.com/forums/powerquest/165079-top-speed-280-silencer.html)
CHAOS REIGNS 08-15-2007 01:11 PM
for my 280 -- unless i have the motor at 4 or higher -- it never chine walks - i do have external add-a-ram hydraulic steering.
runafever 08-15-2007 02:24 PM
Originally Posted by Dave98 (Post 2236001)
RAF, You mentioned about "over trimming". I have a 300 Revenge. At speed, I have the tabs all the up and the motors at about 2-3. What is an indication of over trim? I have always adjusted the tabs and motors for max rpm but we have some what I would call serious chine walk at 75+ mph.
Thanks for any help or advice.
I'm not an expert on Powerquests hull and x and y dimensions of there drive placement but single engine step hulls will have more of a tendency to walk the dog on you than in a twin engine boat. I would try the oposite on a twin step revenge and at WOT try running your drives at 4 and your tabs at 2 and see if this settles the boat down some. Again it is a short hull.
FITZ 08-19-2007 07:46 PM
Have A 2002 Powerquest 28 With Bravo 1 4 Blade Runs 65mph No Chime Walk Has K Planes 490 Ho 425 Hp I Would Like To Go Faster What Prop Are Others Running
pkspx 08-20-2007 11:46 AM
My 270 Laser has a built 454, running about 550hp out of it and use to chine walk before I did the IMCO 2" shorty. I got more top end and a better quaility of a ride. Side by side with my buddies boat I run 72mph.
Pete280 08-21-2007 03:00 PM
Fitz, I have a labbed 26P Bravo, the previous owner also installed a 1" spacer on mine and picked up a couple mph. I have had mine to 69.5 gps with a 502, salt water
FITZ 09-04-2007 06:38 PM
Four Blade Or 3 Blade Bravo 26
Pete280 09-05-2007 09:49 PM
4 blade, pretty sure the 3 blades are called Mirage
