-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   Vyper step pad question (https://www.offshoreonly.com/forums/powerquest/180265-vyper-step-pad-question.html)
JLS 02-19-2008 06:52 PM
Was thinking about machining an aluminum plate to replace the plastic step pad next to the rear seat in the Vyper, Does anyone have access to take a digital picture with a couple of dimensions because mine is in storage for awhile yet. I was going to install rubber pads in these and get them anodized as well if anyone is interested.
Thanks Jeff
Scott 05-06-2008 09:22 AM
Ever come up with anything? I'm holding a 5 1/2" x 4 1/2" plastic pad in my hand It needs to be purple!
Slick02 05-09-2008 11:44 AM
I made mine out of star board, cut the grooves with a table saw, routered the edges and the soaked them in dye for a week.
THRILLSEEKER 05-11-2008 11:03 AM
It may sound cheesey as hell but the Rit Dye method works well and its dirt cheap. Ive used the process on rifle parts before.
Slick02 05-12-2008 07:36 AM
Exaaaaccctly, and the longer they soak the deeper the color gets(to a point)
THRILLSEEKER 05-12-2008 09:58 AM
http://myweb.cableone.net/jsheffi31/...g%20Method.htm Heres a link to how its done.
If you are wanting to dye a light color piece "white" with a very dark colored dye i.e....purple and you dont want your piece to be overly dark, you may want to check it every half hour or so to make sure it hasnt gotten too dark.
Slick02 05-13-2008 07:22 AM
It's amazing just how porous starboard is and how much dye it can soak up if you let it, mine were purple(99 Vyper was teal, purple, black) so the purple came out pretty close.
