-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   Got my dash done (https://www.offshoreonly.com/forums/powerquest/19712-got-my-dash-done.html)
Kentz 03-09-2002 03:24 PM
you're Gafrig speedo, that is:)
Raypanic 03-09-2002 04:00 PM
1 Attachment(s)
Kentz, It is a 4520 from Gaffrig performance (Not Livrosi) 198.00 for head only. 200.00 for GPS reciever (Black only). I hooked mine up to the existing Garmin setup. The gps antenna is mounted right above the cabin door on a small pole. It was there when I bought the boat. I have seen PQ's mounting and it is above the Tab indicators. But they use the analog type guage from Livrosi and there kit includes a white antenna and a recall switch.
Mine has an input for a recall button it allows you to show max speed, RPM, compass bearing, and voltage.
Kentz 03-09-2002 05:06 PM
Got it!
Thanks again
Vyper340 03-10-2002 06:54 AM
I have the color 176 and it works fine in the sunlight. In fact, I have no problem with wash out or seeing the colors or markings. Not sure if the Donzi bubba that you heard that from had it adjusted correctly....
