Go Back  Offshoreonly.com > Owners Forum > Powerquest
Enticer impeller replacement >
Old 06-02-2009 | 06:57 PM
Originally Posted by johnny b good
Mabe blockage at in the oil cooler?
Yep, that's what I'm thinkin'.........but even there, it'd have to go thru the impeller first. I'm planning to remove that whole line Friday and see if anything is in there.....thanks
AngerMgmt is offline
Old 06-03-2009 | 04:04 PM
I am in the process of replacing my sea water impeller on my 22 Raizor. I just took the walls out of the bilge compartment and pulled off the fuel filter. From there it was a straight shot to the pump.
interOctave is offline
Old 06-03-2009 | 06:14 PM
Originally Posted by AngerMgmt
Well Fellers, I appreciate the replies.......I took the seat back out and found the sea water pump impeller in perfect condition. I also back flushed the intake hose back thru the outdrive and back flushed the hose that goes out from the pump and up to the thermostat housing thru the cooler. Splashed the boat last Friday and it stays at 150 when going "coal barge" speed, but jumps up rapidly when I get up on top of the water.
I'm guessing a partial blockage somewhere......any suggestions???? Thanks
I drilled four 1/8" holes in my thermostat. Dropped my hard running temps and cruising temps are more stable.
MacGyver is offline
Old 06-03-2009 | 06:16 PM
How could something get that far to cause a blockage unless some rust? Heck, I can't see how anything got past the impeller without damaging it. I'm assuming something (trash) got sucked in thru the intake because the water is full of crap...we've had record May rains. Also, I've got Imco lowers which have a large water intake along the leading edge. Backflushing did yield one small piece of wood...........
You need a sea strainer........soon
MacGyver is offline
Old 06-03-2009 | 09:06 PM
I'd love to have strainers, and would, if I could figure out a place to mount them. I have 4 batteries and the engine compartment is so full, I might have enough room for a handkerchief and a handfull of loose sand
