-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   Insta Trim 200 indicator problem/Question (https://www.offshoreonly.com/forums/powerquest/211812-insta-trim-200-indicator-problem-question.html)
murf 06-26-2009 05:37 PM
I have a 2000 280 Silencer. It has insta tabs with the insta tab200 indicator. My port tab indicator lights up all the way indicating the tab is down when it is not. Has any one else had this problem. Both tabs are working fine. Any suggestions on where to start looking. Would it be on the tabs or the indicator panel itself? I would appriciate any input.
Thanks!!!
MC-BOYS 06-26-2009 09:14 PM
Thanks!!!
check your the cylinder on the tab for any leaks; had to replace both pair of cylinders on my tabs on my old powerquest. Purchased them directly from Instatrim.
Goodluck with your investigation.
specialk 06-26-2009 09:50 PM
I took the indicator off the cyinder and cleaned it. It happened from the lines leaking. Then zip tied it back on. Works fine. What kind of power do you have in your 280? I just bought one and I am trying to figure out what kind of cruising speed I should be getting around 3200-3500 rpm.
murf 06-28-2009 06:25 AM
Thanks for the replys, I will check the cylinders fro leaks and clean the indicators.
specialk, I have a 502. I run abbout 45 at 3500 RPM,s Top speed was 68, two people, half a tank of gas. I jusy got it at the end of last year, still need to get more time with it.
MC-BOYS 07-02-2009 09:42 PM
Where do you boat in NJ?
murf 07-03-2009 05:02 AM
MC-BOYS,
I keep my boat at Sea Village Marina in Northfeild. I'm up at Trump Marina and that areae a lot. How about you?
MC-BOYS 07-06-2009 08:17 PM
Originally Posted by murf (Post 2902265)
MC-BOYS,
I'm down in Wildwood/Cape May area. Typically go to Champagne Island between Stone Harbor and North Wildwood. Great place to hang. If your ever planning to head down my way, drop me a PM. I'll do the same if planning on running up to AC for a quick ride.
Mike
