-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   34 vyper gaffig gauges (https://www.offshoreonly.com/forums/powerquest/237999-34-vyper-gaffig-gauges.html)
mcr vyper 08-30-2010 07:27 PM
Recently bought a 2002 vyper with twin 496 mag ho's. Having a problem with coolant temperature gaffrig gauges. At night when you turn on the dash lights the temperature gauges for the engines go up 20 degrees and it goes over 180 degrees which causes the overheat light in the middle of the gauge to come one. When you turn the lights off the temperature drops back down to a normal reading. Anyone run into this? Any help or advice on how to fix would be great.
Thanks:party-smiley-004:
boatnt 08-30-2010 08:17 PM
Yep,been there done that!
You need to run a thicker ground wire to the dash.
JLS 09-07-2010 12:18 PM
Same Problem
Where did you run the ground from and where did you connect to at the dash?
mcr vyper 09-07-2010 07:18 PM
I did not run the ground or install the gauges ,we just bought the boat few weeks ago.Had the boat down at loto when we noticed the gauge problem.
specialk 09-07-2010 08:15 PM
My 290 always did that. Fiqured it was normal and never worried about it. Did not do much night boating though.
johnny b good 09-08-2010 03:40 PM
My boat with nav. lights on bumps up the temp on the engines about 10-15 degrees warmer on the gauges, and when I run the blower motor my gas gauge drops about an 1/8 of a tank.
laszlo01 09-08-2010 04:44 PM
Clean all the gauge connections and grounds, should fix it.
mcr vyper 09-13-2010 06:48 AM
Ran a new ground wire ,fixed the problem, Thanks
boatnt 09-13-2010 08:35 AM
:drink:
