-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   502 starter (https://www.offshoreonly.com/forums/powerquest/255317-502-starter.html)
Jplanes 06-07-2011 10:07 AM
502 starter
Hey guys, I believe I've lost a tooth on my starboard engine starter. I can still get it to start, but sometimes it takes a couple of attempts to get the teeth to catch. I didn't look real hard the last time I was down there and I've looked up on line the location of the starter. So my question(s) are: Is the starter on the front left
side of the motor towards the bottom of the block? Second: Has anyone done this and did you have to take the exhaust manifold off? Just wondering how hard of a job this is because of the limited space? Thanks!
Jake
AngerMgmt 06-07-2011 03:11 PM
Jake, your starter should be on the left side (looking at the pulleys) at the back. The sea water pump is on the left front.
You can do it.......just find a double jointed midget with three arms. Good luck! Mark
Jplanes 06-07-2011 06:49 PM
Mark,
I'm in luck because I keep one of those in my basement for just these situations! I was nervous there for a second that this was going to be easy!:angry-smiley-038:
After some research on line it looks like you are correct. Not looking forward to this but it has to be fixed! Thanks
Jake
cocktails 06-07-2011 09:08 PM
Originally Posted by Jplanes (Post 3423560)
Mark,
Jake
j planes r u running twins if yes is it the inside starter port engine
