34 viper AC install?
Can anyone help me out with some info from here? Im looking to install AC on my 34 viper. Was wonding what type the factory used to install, how many BTU'S, and where it is located at? Ive heard behind the refridgerator. Also any body know what type they were, and where the fresh water pump is mounted? Any info or pics would be appericated. thanks,
My 2001 380 has the A/C unit behind/beside the fridge, the air intake is there and outlet above the electrical panels. The water pump is under the step coming in from the cockpit. Sorry don't remember the brand...all the manuals on the boat.
I've seen pics of aftermarket installs under the center of the seating just below the berth. |
2 Attachment(s)
A/C pics
Thanks for the info and pics - much appericated. If you think next time your on the boat let me know the brand and size btus of the unit you have.
regards ~ |
Is this something you're looking at doing yourself?
Installed my own unit in my 340. It is a 5000 BTU cool only unit mounted under the center seat in the u shape lounge. Lots of cutting. If you are going to do it yourself make sure you know what you are doing. It is not a simple job. Good luck.
| All times are GMT -5. The time now is 03:21 PM. |
