-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   best way to get a great sound outa 454 mage? ??? (https://www.offshoreonly.com/forums/powerquest/260958-best-way-get-great-sound-outa-454-mage.html)
dra200832 08-24-2011 07:54 AM
K so i got a 454 mag that sounds ok. But i want louder. What the best way for that with out spendi g 1000s of bucks
Knot 4 Me 08-24-2011 10:17 AM
Assuming your current exhaust tips have baffles in them, replace them with a set of straight-thru tips. The next step would be to replace the stock cast-iorn manifolds with a set of aftermarket manifolds such as Stainless Marine. Better yet, add a set of Lightning or CMI E-Top headers.
diggin H20 08-24-2011 12:41 PM
Unless someone changed them to something else I put slash cut Corsa tips on the boat when I bought it. It did have the tips with baffles and was too quiet.
Fenderjack 08-24-2011 12:52 PM
Not gona get much for 1k unless you can find some decent dry pipes used.. New BBC stuff is exp.. Remove any baffles like said.. Exhaust is the only thing that is going to make it louder, unless you change cams, up compression, get the HP sound..
John jr
