single-engine enticer
ever seen one of those?...the single-engine enticer 29 was available with a single bbc-at least on paper....i have yet to see one...im asking cause i wouldnt mind owning one if they are around
thanks |
Unless it had a turbine it would be a PIG. Boats that size need twins.
Originally Posted by POWERPLAY J
(Post 3544867)
not sure....i have a 27 lazer with approx 625hp,and it runs like a bat out of hell...easily spinning a 25+m...a single enticer cant be that much more heavy??
Ya prob not. My 280 weighs 4800. the 29 prob weighs 52 at most. a stout 525 would make it run good.
290 weight is 6500lbs
Originally Posted by boatnt
(Post 3545047)
and then the weight would be in the 5500 lbs area... |
Originally Posted by verbi69
(Post 3545052)
With twins..........deduct 1000lbs for one engine and drive assembly???
ok...whos going to be the 1st to call the factory and order one??
(Post 3545052)
| All times are GMT -5. The time now is 06:00 PM. |
