-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   Removing Painted Registration (https://www.offshoreonly.com/forums/powerquest/273351-removing-painted-registration.html)
PQ260SX 03-29-2012 09:16 AM
Does anyone have any tips or product recommendations for removing painted on registration numbers without hurting the gel coat?
boatnt 03-29-2012 12:50 PM
easy off oven cleaner
Need4SpeedGTCS 03-29-2012 01:34 PM
Easy-off works great on enamal paint that is mostly for vehicle lettering, not sure how it will affect gelcoat. You may want to buy the squirt bottle (non-arosol) so you can brush it only on top of the numbers.
Any of the paint guys on here have any experience?
Powerquest_Baby!! 03-29-2012 02:58 PM
No, but I know its safe for gelcoat. Alot of guys use it to remove bottom paint.
verbi69 03-29-2012 05:44 PM
As Boatnut said, easy off.
Painters enamel usually is not the toughest to remove.
boatnt 03-29-2012 06:55 PM
listen to me now hear me later,,,,LOL
JETTDOGG 03-30-2012 11:41 AM
Breakaway spray - let it soak in. Sounds foolish but it took dry d.o.t. Line spray off my hull.
PQ260SX 03-31-2012 07:23 AM
Sounds good guys. As always, I appreciate the help. I will give easy off a whirl and let you know how it goes.
pquest260legend 04-05-2012 10:54 PM
The boat name was painted on my old libertor. I buffed it off with compound and a wool pad. No problem.
PQ260SX 04-06-2012 03:10 PM
The easy off worked great. A little word of advice for anyone about to do the same thing. Cover your trailer with a rag towel in case any drips (it will remove paint there too.....) and DON'T get any of the easy off on your skin or you will pay for it. Then of course the only problem is that under the painted numbers the gel coat hasn't seen the light of day since they were painted in 1997 lol......
