New Gaffrig Gauges
I put all new gauges in my 95 Avenger and I assumed the old ones were the orignals. The Oil Pressure & Water Temp. gauges do not work. When the the ignition is turned on they peg all the way to the right. All my other gauges work fine. I did purchase new senders for the Oil Pressure gauges, but not for the Water Temp.
Any thoughts???? |
Most likely the wrong ohm range id think ..
Almost sounds like they are receiving a ground...what happens once you start the engine?
Are you sure you hooked them up correctly? (just asking) |
Originally Posted by Pwraddr
(Post 3799585)
Originally Posted by pqjack
(Post 3799613)
.ask me how i know..
I'm pretty sure they are wired correctly, I did one gauge at a time and verified with the one still originally wired. When I start the engine, the gauges remained "pegged" to the right. The only thing different on these gauges was how the light was hooked up. I ran a jumper wire from the ground for the gauge to the one side of the light. I wouldn't think this would be an issue???
Originally Posted by Don OHIO
(Post 3799685)
Hope this helps... |
I pulled the ground jumper wires today (from the gauge ground to the light ground) on all 4 gauges. Started both motors up to winterize and still nothing....the oil pressure gauges still pegged to the right, but now the temp gauges are at zero instead of being pegged right. Looks like this will be a spring project!!!!
| All times are GMT -5. The time now is 06:09 PM. |
