2nd round mods done!
1 Attachment(s)
Here are som pictures of the recent mods I have completed:
Gaffrig Outlaw switchable mufflers and New Latham tie bar: |
1 Attachment(s)
Bimini top "Glass" installed in front:
1 Attachment(s)
I added Drive temp indicators and re-work botom right panel with clock, Air/water temp gauges and reset switch for GPS The depth guage was moved to in front of the throttles. I also replaced the trim rings on the lower dash with the angled ones. I thought they might look hoakey but they turned out nice and you can read the gauges better:
1 Attachment(s)
RH Panel
1 Attachment(s)
Shut off valve on sea strainers, Not as pretty as Scotts but they are brass. Wat a ***** to get at and done. I had to use my "Skinny Guy"
1 Attachment(s)
My generator, It will run my heat and air! and fits nicely under the seat for travling. I will move it to the transom platform for running as the fumes dont go away very well down there :p . Only weights 60 Lbs and will run for 8+- Hours running the air.
Nice Ray!
Now stop playing around and use that thing!!!!!!!!!:p |
Ray, looks very nice :).
Those mufflers are huge and might be a PIA to keep clean :( but I am sure keep those DB's down quite a bit. Like the generator. Glad to see you bought a quality one :). All my stuff is Honda, it is the most reliable, most fuel efficent and very quiet. :) Just be damn careful where you park it while running so that you don't fume yourself to death. Put in a few CO detectors for added safety. Jeff |
"Put in a few CO detectors for added safety. "
I second this. If you have one might need to check & see how old it is. About a 1 1/2 year ago had a news chopper guy die from CO. The guy was not a dummy but left generator in the back of a horse trailer & fumes worked their way into the sleeping area. |
Thanks, I should have one on board anyhow. I will have to pick one up.
| All times are GMT -5. The time now is 12:16 PM. |
