-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   What are you towing 340 Vypers with? (https://www.offshoreonly.com/forums/powerquest/294508-what-you-towing-340-vypers.html)
East Coast B 04-12-2013 05:21 PM
I've got a 2002 Ford F350 7.3 Diesel 3.73 rear and tow in hilly areas and have towed a 31 Sonic around which weighs in at 7,000 lbs. On the big hills, that 7,000 lbs was a bit tough to keep going up to the top. The auto really needs another gear. The Vyper is a taller larger boat and says it weighs in at 7500lbs... Is that a true number? It sure looks big on the trailer. Anyway, what are you towing Vypers with in the hilly areas. If I lived in the flat lands, I'd be buying a 38 footer without question!
Thanks everyone!
Pwraddr 04-12-2013 05:29 PM
Hello, I use a one ton dually Ford Powerstroke 6.0.
There is a thread on weights in here but mine is just shy of 6 ton.
Pwraddr 04-12-2013 05:32 PM
Here is the thread.....
http://www.offshoreonly.com/forums/p...er-weight.html
East Coast B 04-12-2013 06:44 PM
That answers my question... Back to the drawing board!
Thanks guys!!!
Pwraddr 04-12-2013 07:00 PM
Your truck should pull 6 ton without any issue...shocked to hear that it struggles with 3.5 ton.
offshorexcursion 04-12-2013 07:25 PM
Your truck will tow a 34 or 38 that sits on a good condition trailer and the trucks in good condition. I use a cummins ram to tow 50 ft 3/4 car trailer through every mountain pass in the country. Weighing 25-30,000lbs daily.
East Coast B 04-13-2013 04:30 PM
3.73 rear is the killer.... scale weights from the link above for the vyper shows a lot more weight than the 31 sonic loaded with trailer... I could go a little more weight but those numbers are a little more than I think I'd be comfortable with....
Again, appreciate your time guys!
Pwraddr 04-13-2013 07:38 PM
I think the point is that your rig should pull without issue.
Tinman003 06-19-2013 03:45 PM
I just pulled my '96 340 from lower Michigan last week with my '09 Chevy 2500HD, Duramax/Allison. The winning combo. Set the cruise at 74 and it pulled like a dream at 9 1/2 miles to the gallon...
