-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   380 Avenger TV (https://www.offshoreonly.com/forums/powerquest/294665-380-avenger-tv.html)
Cory H 04-15-2013 08:21 PM
380 Avenger TV
I plan to add a 24" LED/LCD/DVD TV to our 380. The boat was not originally equipped with the TV. The Shorepower panel has a switch though.
Is the wiring there near the factory location? If not, how do I go about getting the wiring in-place? I see there is a removeable panel in the headliner, fore of the dash area. Is there a panel in the floor that comes out to run them underneath?
Any ideas are appreciated.
johnny b good 04-16-2013 12:55 PM
I’m not sure if there would be wiring there or not. I replaced my Factory installed 12 volt 9” TV vcr combo with a 19” 12 volt led flat screen tv from Jensen, and a 12 volt dvd player from Nesa model 1002, which I mounted under the cabin couch seat storage area. That headliner piece comes off because I routed a new RG6 coax cable from the tv over and down to the AB switch in my hanging locker. You should be able to hide and snake any wiring you need from your electrical panel, hanging locker, stereo receiver area back to the tv in that boat.
Cory H 04-16-2013 05:34 PM
That's reassuring, thanks.
