2001 280 Silencer fresh 502 running slow help dial her in please!
My good buddy has a really nice 2001 280 silencer with a fresh merc 502mpi spinning a 24 b1 about 5100 rpm at 60mph. What's wrong?
I plan on driving the boat tomorrow anything I should know to help him out? How far does These boats like to be trimmed up? Tabs? I'm pretty good at getting a feel for what a boat wants but also am not afraid to learn from the power of OSO.
Overall I am really impressed with his boat it just needs to go the speeds we thought it should..
Post your speed, prop, rpm, and propshaft height please.
Thanks!
Thanks!
Last edited by offshorexcursion; 07-02-2014 at 09:09 PM. Reason: prop pitch is 24 not 26
I also have a good friend that has a 2000 280 silencer with a 502mpi. He is spinning a 4 blade, 26 pitch b1. In perfect conditions with 2 people on board, he will run 67mph with some trim. RPMs at WOT are around 5000-5100. I don't know the exact propshaft high but I know it was never raised, so probably the same height as your friends boat. I hope this help a little bit.
A Bravo 26 pitch will kill your top rpm as your already at 5100. These boats do not like a whole lot of trim. The boat hull will feel like it frees up and feel faster when in fact a gps will show it slowing down in mph.
My 03 with a stock 496HO would run 64-65 mph for comparison. With 565HP it ran 73ish....
Cutting Edge Laser Labbed Prop
67 with a 26" is actually right on the money for that boat (I had 74 MPH-GPS at 5400 RPM with the same prop/same boat with a 525 EFI-17% slipage with a single person in it, 28" regular Bravo 1, same speed at 5100 RPM, too much prop, currently right at 80 MPH with the 28" Cutting Edge Laser Labbed prop, take's off a little slow at 1/2 or full throttle but once on plane, it takes off like a Corvette), it's the best prop by far and it's not even close, their laser labbed props will get you the maximum RPM's and top end, they look like a they were sharpened with a sharp knife sharpener on the forward side, you can practically cut yourself on that edge they are that sharp, Mercury Racing has nothing like that. For the ultimate blast, there is a 575 SCi (which is all an XR drive will take away) on Ebay right now for $16,000 and it will fit in that boat and it should run 30" Labbed CE Prop 80-85 MPH maybe 90 MPH after Tyler Crockett tunes it, he's Mr. Wizard with Mercury Racing Tuning.
24 pitch should around about 67 MPH at 5150 RPM without trim, I started off with a 525 EFI with a 26 pitch and it ran 70 MPH at 5400 with some trim, so a 26 pitch might be a little steep for that powerplant.
