Cabin Door
We went to Kelleys Is. Friday when we got there I tried to open the cabin door and it was stuck. I got it open only to find a couple of rollers broke off the bottem of the door. Has anyone else had a problem like this? I think it has to go back to the factory to get fixed! Is there a simple way to get the door out? Thanx for any info..
PM Scott, he told me of the same problem that he had with his, The factory sent the rollers and suggested a large cut out of some type, He found a better way with no cutting.
My door is a different style (older) than Snopro's I have some type of glide or block that rides in a track. I fixed the problem with the small screws holding the glides to the door. Now I have to fix the track :eek: . Two poker runs did it in:rolleyes:
I have a problem with my cabin door as well. Can't see a way to remove the door without major demolition. The bottom track is broken on mine. I can see the problem, but can't get the cabin door out to fix it.
Anybody have experience at this fix? Jon |
The door is flexible you will be supprised just how far you can push it out to allow access to the track.
Hum? Stress cracks, doors broken, maybe I shouldnt sell mine, none of this stuff has happened to mine.
| All times are GMT -5. The time now is 02:44 AM. |
