-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   PQ problems or advice (https://www.offshoreonly.com/forums/powerquest/326681-pq-problems-advice.html)
murf 06-05-2015 08:58 PM
You wont be disappointed with the PQ. They are great boats. I have not seen another PQ where I boat, but I like that.
What size/model baja arer you test driving? Have you driven the PQ yet?
Kicker82 06-06-2015 08:39 AM
I have looked at bajas before and they just felt cheap on the inside. Since I am in Michigan there are a ton of powerquest around me and I love them. The amount of room compared to the fountain and checkmate is really nice (I have buddies with both). I like to think of powerquest as almost a poor mans formula.
jus roamn 06-07-2015 11:08 AM
Powerquest did follow a lot of designs from Formula. I think of them as an affordable Formula-like boat.
Pockey 06-08-2015 07:52 AM
The baja is a 275 boss, really nice, both boats have their features that I like. Not sure which way to go. I guess i could wait till one sells and buy the other one.
apollard 06-08-2015 08:33 AM
IME, the build quality of the PQ is much better than the Baja. It will hold up better. The only area I've had to 'fix' on mine has been the wiring - while the hulls & interior are above average build some of the electrical was average construction for the marine industry. I've seen big name factory boats with worse. Some of the connections will need some work after a while.
Heck, mine is a '94 with original vinyl, foam and wood on the interior. Only a few surface cracks on the deck or hull and everything still working (seat hardware, etc). It's not babied either, it get wet everyweekend and stored outside. A buddy has a '02 and the quality seems just as high. You'll be hard pressed to find better value IMO.
Pockey 06-08-2015 12:57 PM
Thanks for all the input. I think the boat is in really good shape. I may go try to make him an offer this weekend if i can get away from this dang job long enough.
