-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   how to choose prop pitch&number of blades (https://www.offshoreonly.com/forums/prop-talk/101613-how-choose-prop-pitch-number-blades.html)
crazy canuck 04-25-2005 07:03 PM
I have a 1984 30'scarab blown454's aproximate horsepower 600 trs drives .If i run a four blade prop what pitch should i use keeping the rpm's 5500 to 6000 looking for top end speed?
bbladesprops 04-25-2005 07:46 PM
Re: how to choose prop pitch&number of blades
What is the wet weight of the boat?
This includes fuel, people, gear, food, beer, ice, etc., etc.
What is your gear ratio?
crazy canuck 04-26-2005 02:22 AM
The drive ratio is 1.5 to 1 ,the weight i'm not sure but i guess 7800 8000lbs ?
throttleup 04-26-2005 06:50 AM
Start with a 24 or 26 Bravo 1 or 23 through 25 Hydromotive. The 23 or 24 should put you in the top end of your rpm range while the 25 or 26 should put you toward the bottom end of your rpm range.
Matt
bbladesprops 04-26-2005 08:48 AM
26-28 Bravo 1 depending on how accurate your weight is.
I figured you to run the engines in the 56-5700 rpm range in the mid 80's
