-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Best way to increase midrange ? (https://www.offshoreonly.com/forums/prop-talk/103937-best-way-increase-midrange.html)
mmwalters 06-22-2005 10:04 AM
Re: Best way to increase midrange ?
Bern I am insterested in your results. My props rotate "out". When I changed to rotate "in" the bow lift was incredible, just a short touch on the button and I had way more lift then I wanted, of course our hulls are different and the Motion has a very wide tunnel (45''). I noticed no difference when docking but my top speed dropped 4-5mph in back to back test. The skaters seem to favor turning the props in. Post your results
mmwalters 07-05-2005 07:59 AM
Bern I ran those 29'' hydros 4 blades on my motion saturday. Real simple.. they are not the props for my boat, struggled to plane, expected that (thru hub) not much mid range and I could not pull them over 5000rpm about 76mph. I went home and pulled the spark plugs as I though maybe I hurt a motor. Installed the 34'' 3blade cleavers and ran 104mph in the heat. Hard to understand how they could run almost 30mph slower then the cleavers!
