-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   need help (https://www.offshoreonly.com/forums/prop-talk/104143-need-help.html)
dsandman6 05-25-2005 08:09 PM
need help
I have a 25 outlaw 385 mag mpi the boat had a23 mirage plus and ran 62.5 I tried a 25 mirage got 64.4 at 4700 rpm everybody told me to lab the 25 so I did well then I could only get63.0 at 5000 rpm then they told me to put some cupping in it well after that now iam getting 63.4 at 4900 rpm do you have a clue why this is happening its driving me CRAZY thanks for any help Randy
docmanrich37 05-25-2005 08:19 PM
Re: need help
maybe you should leave the full cooler on the dock, to get the extra 200 lbs. off the boat before you do a run.
dsandman6 05-25-2005 08:23 PM
Re: need help
seriously bro this is driving me crazy the speed did not change after the cooler was cleaned out
hillbilly24 05-26-2005 12:19 AM
Re: need help
1 to 2 mile an hour difrences are realy not as conclusive as they seem, all though see conditions may have lloked the same, it only takes a very slight diffrence in water, temp or humidity just to name a few, that could result in the diffrence you are seeing. the only way to realy compare props is to test tehm all in the same outing, although I know this isn't possible when you have to sedn yours in to have the mods done to it.
wcmarine 05-26-2005 08:56 AM
Re: need help
Who did the work on the prop???
dsandman6 05-28-2005 09:59 AM
Re: need help
throttle up did the prop so i know its right i am just wandering why i am having the decrease in speed i am going to try a 23 this weekend again then come in and change to the 25 again get some good numbers then call julie and see what she thinks
throttleup 05-31-2005 08:40 AM
Re: need help
Sounds good.
Julie
docmanrich37 05-31-2005 09:25 AM
Re: need help
Randy your not still at the party from sunday are you.let go of the brass pole no one wants to see you dancing.lol
dsandman6 05-31-2005 08:20 PM
Re: need help
You know if you would hurry up and pull those 525s out and sell me one i would not be having these problems :D
docmanrich37 05-31-2005 08:26 PM
Re: need help
No but the 572 has your name on it since Debbie and i worked out the payment plan.don't worry about the deposit she's taken care of that too.
mwdill 05-31-2005 09:12 PM
Re: need help
yea, he only use's 1 anyway!
docmanrich37 05-31-2005 09:24 PM
Re: need help
[QUOTE=mwdill]yea, he only use's 1 anyway![/QUOTE
Only need one so the A/T is SLOWWW right Randy.lmao
