-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   5 Blade on Pantera (https://www.offshoreonly.com/forums/prop-talk/104628-5-blade-pantera.html)
Full Throttle 525 06-02-2005 02:37 PM
5 Blade on Pantera
Hey Guys:
Anyone try a 5 Blade on a 28 Pantera with a single 525 EFI?
If so, what were the results?
Thanks,
Ron L.
throttleup 06-02-2005 03:30 PM
Re: 5 Blade on Pantera
Yes, there are several out there with 5Bprops on them. They typically run best with Hydromotive P5's or Herrings 5B props.
Julie
Full Throttle 525 06-02-2005 03:59 PM
Julie:
What do you suggest? Right now I'm running a 26 labbed 4 blade turning 5000 rpm's around 69.9.
throttleup 06-02-2005 04:58 PM
I'd start with the 24 pitch, that should get you in the same speed range as you are now. The major improvement with the 5 blade is the handling and acceleration. They are great in choppy or rough water.
Matt
Hessdk 06-06-2005 10:41 AM
Ron, check your email. David
Full Throttle 525 06-06-2005 11:27 AM
David, I checked my mail, nothing there. Please email to [email protected] Thanks, Ron
Full Throttle 525 06-07-2005 12:30 PM
David:
Thanks for the chat and information. I'll let you know how I make out.
