Bent Blades? Home repair How to?
Directions please on how to remove and correctly pound out a bent blade on a SS prop?
mounted on a Yamaha OB Thanks Evan |
Re: Bent Blades? Home repair How to?
You can't do it "correctly" without the blocks for the prop.
I'm going to do it anyway, so please help me out.
...the real trick is to buff it when you're done. That's what makes 'em look so good. |
The most difficult part is mounting the prop so it can be worked. Typically if it's not worked on a block it is mounted to a very heavy steel table. After it's firmly mounted use a couple of hammers and start working the prop till it looks right. You can get pretty close just by eye balling it. Steel hammers will leave dings in stainless steel. Then start sanding it with progressivly finer sand paper, buff it up and you are good to go.
Or send it to Julie @ Throttle -up, they did a prop for me last year and I gartuee it looks better than yours. :-)
J/K, I just wanted a chance to plug the good folks at Throttle up. Mike |
Dings in props usually translate to bends in prop shafts that should most times are not visually detectable. You should have your lower unit checked out.
Begin by running a TIR (total indicator runout) on your propr shaft. If you do not know how to do one this would be a good time to learn. A TIRis real simple and can be performed right on the boat. |
Roby |
Originally Posted by robyw1
Now that is determination! :D:D:D
Roby |
Phone # for throttle up please?
| All times are GMT -5. The time now is 08:11 AM. |
