-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   which prop Donzi 22zx (https://www.offshoreonly.com/forums/prop-talk/105372-prop-donzi-22zx.html)
snake plissken 06-12-2005 02:54 AM
Hi I have a Donzi 22zx 454MPI 310 HP dana headers jacobs ignition and k&N filter currently have a bravo 1 lab finished prop 22pitch my boat at WOT will do about 60mph at 4200 rpm. im sure i can do much better on top end. the boat planes out great after i installed the edge hydrofoil and it dint afect my top end at all runs the same top end with or with out the hydrofoil. im also in new mexico and the lakes here are about 4000 ft above sealevel. im open to any ideas on what prop i need to get more top end and more rpms
Thanks Vince
snake plissken 06-13-2005 09:01 AM
Re: which prop Donzi 22zx
Come on guys help me out :(
onesickpantera 06-13-2005 09:24 AM
Do you have a 1.36 drive ratio?
snake plissken 06-13-2005 10:13 AM
yes im pretty its 1.36 ratio
bbladesprops 06-13-2005 10:19 AM
A 3BL propeller should reap the largest returns on top end for your boat. In order to reach higher rpm figures you may need to consider lower pitches.
snake plissken 06-13-2005 02:10 PM
so are you thinking a 23 3 blade or 24 4 blade and having a lab finished to a 23 ?
320es 06-13-2005 04:34 PM
My buddy just had a 22 laser labbed by throttle up for his 20' checkmate, same motor and drive. Slipps a little out of the hole but once its going it runs its a$$ off. He picked up 4mph on the top and it cruises well too.
snake plissken 06-13-2005 08:07 PM
which prop did he have labed up was it a 22 4 blade
onesickpantera 06-13-2005 08:53 PM
If you need more rpm you need less pitch. Or your current prop labbed. What rpm do you need to run?
DustinM 06-14-2005 12:32 AM
1 Attachment(s)
I have a friend with the same boat and motor. He has tried many props and none work as good as the Bravo 22p. 3 blades wont come out of the hole for crap, but will run a few more on top end. The trade off was not worth it. Cruising sucks with the 3 blade too. We boat on Powell 3600' elevation. He gets around 55mph at 4400-4500rpm
throttleup 06-14-2005 07:48 AM
The torque band of a stock 454 MPI is 4600-5000 RPM at WOT. So at 4200 RPM you are lugging your motor. However with a 22P Lab Finished propeller you should be there. So you need to verify a couple of things.
Confirm Your:
Propeller pitch
WOT RPM, verify your tach.
Additionally I would verify your speeds, via gps and verify your gear ratio.
When testing for WOT RPM you should also be trimmed for speed when recording this data.
Julie
onesickpantera 06-14-2005 10:47 AM
I thought the 310 and the 330hp motors were carbed that ran 4200-4600 and the MPI motors were 365 and 385hp and ran 4600-5000. There was a 310hp MPI motor? :confused:
bbladesprops 06-14-2005 06:37 PM
noboat is right. It is sometimes difficult to remember all the 454 combinations built. The 454 mag mpi is 385 hp fuel injected and the WOT range is 4600-5000 (not the torque band), with a rev limiter @ 5150(if stock). The torque actually falls off slightly after 4600. I would agree, Labbing the 22 Bravo 1 is a good idea. Another great prop is the Rev 4 Labbed at 21P.
