Best props for non-stepped 38 scarab
Hey, I have a 1989 Wellcraft 38' Scarab and I need to know the best props available for top end speed. Right now i have bravo one's with 23 pitch blades and I feel I can get more speed out of my boat. The boat weighs ~9000 lbs.
And also, I have my props rotating outward as of now. Would switching then to rotate inward cause the boat to have more top-end? Thanks |
Re: Best props for non-stepped 38 scarab
I assume that your 23P propellers are 3B props. If you can post your performance data I will run some numbers and look at some options or you.
What is your WOT RPM? What is your WOT MPH, via gps? What make is you 23P? What gear ratio and drive type? Julie |
| All times are GMT -5. The time now is 01:48 PM. |
