Re: Diffuser Rings - what do they do?
The first thing I do to my props is cut the ring off. I haven't seen any negative affects from removing it as far as time to plane or midrange speeds. I do see an extra 3 mph on the top end.
I run Merc Labbed B1 props on a 41 Velocity |
Well thanks all for your imput.......tomorrow we are testing a set of 34 "s
without the ring...... if I can pick up 3 mph I'll be thrilled......let ya all know. L.S. |
p4-33...Just noticed you are from "Downriver"/Gibraltar. Does Hedke still own the Gibraltar Boat Yard? My dad built that marina from swamp in the mid-50's & sold it in the late sixties, to move to Florida. Back then, it was called "Humbug Marina". Ed
Nice family, class operation. What's your dad's name? I'll say "hi" for ya. Cheers, Brian |
Originally Posted by lucky strike
So did you try a set with the rings cut off? We have 4 blade props.
Brian |
how much would taking the ring out hurt bottom end?
heard 2 different sides |
Lucky Strike did you ever get the chance to test out the props with and without tthe diffuser ring? If so what were the performance #'s? Thanks
mwdill,
With through transom exhaust it should affect low end planing little to none. |
Originally Posted by bbladesprops
mwdill,
Where I live you can only go 25 mph in the ICW. L.S. |
| All times are GMT -5. The time now is 04:53 PM. |
