Prop ID
What kind of props are these? 48-74600-21 & 48-74599-21? Three Blades. Thanks
Re: Prop ID
They are the old style Mercury Cleavers 21P RH & LH rotations.
Julie |
Re: Prop ID
How would they peform on a 88' 31 Cig Bullet with TRS Drives?
470HP per engine with b w transmissions 1-1.5? Currently running Hydro Q4 22 pitch. Thanks |
Re: Prop ID
Well, they are a semi cleaver blade as well. I would suspect that you will loose some of your performance as the Mercury props are 3B's. So you hole shot will decrease, cruise speed as well. But they may a bit faster as they are 3B's.
Julie |
| All times are GMT -5. The time now is 10:54 PM. |
