Vented or Non-Vented
Whats the real difference between a vent hub and a non-vented hub???My 23 Mirage PLus is non-vented and spins at 4800, Will the vent provide better plane time?
Re: Vented or Non-Vented
What is the boat and motor set-up?
What happens when the boat gets up on plane, does the motor bog down or does it spin to a high rpm and feel like the prop is slipping? Matt |
Vented propellers will have holes of different sizes drilled in the leading edge of the prop just above the labirynth seal. Some ventig like Mercury's PVS system are adjustable with different size plugs to control the amount of exhaust gasses being released. Upon acceleration, the holes allow the exhaust to aireate the high pressure side of the blades so the rpm can come up fast. Once the boat is planing, the holes are really non-existant as the pressure differential inside the hub draws all the gasses through.
Answering Matt's questions will help to answer your second question. Oh yeah, over hub exhaust propellers like choppers and Lightnong ET's are true vented propellers! They are also very fast on the top end with the right boat because ther is no drag from the outer hub. |
I have a 26 Powerquest running a 454mag EFI 385hp spinning a standard Mirage Plus 23 at 4800 rpm at 60-62mph pending load and air temp. My thought was if the vented hub assisted in allowing the prop to slip could I spin a 25 Mirage Plus to increas top end?? More than likely not just a thought??
The vented hub is to help the boat get on plane. Typically for outboard applications. They will not help you to pick up rpm or speed at WOT.
After the boat is on plane it's almost as if the holes in the hub were not even there. The hydrostatic pressure of the water becomes greater than the exhaust pressure as the boat picks up speed and the water pressure keeps the exhaust gasses from coming out the holes. There are some down sides to the vented hub but for the average pleasure boater they do not pose a problem. Matt |
Hi!
I received your blueprinted Tempest 27 PVS this week, and it looks & perform just great. My stock A45 Tempest 25 came on plane instantly, but hit the rev limiter. The Tempest 27 is slower up in plane, expecially with 3-4 persons onboard. As you said, the PVS system will help to get the engine rpms rise. The current plugs can be changed to bigger ones. I presume the local Merc dealer has larger plugs to help the engine rpms to rise faster. Does larger PVS holes have any downside re. cruise speed / wot speed? Cheeeers! Toffen G - Norway :rolleyes: |
No, the PVS plugs will not affect your WOT rpm.
The part numbers and sizes for the PVS plugs are as follows; 19-889725028 .280"/7mm 19-889725035 .350"/9mm 19-889725047 .470"/12mm You can mix and match these plugs until you find what works best for you. You may even find that you may want one hole plugged and the other two open, whatever works for you. You can also drill holes in the solid plugs that are in the prop already, or remove one or all of the plugs completly. Matt |
I have a 30 foot shadow cat with twin 300 promax and I am spinning 28 bravo 4 blades that have been labbed.When I put the throttles up the engines need a little time to spool up and then the props cavitate and up I come on plane and off I go.It usually takes about 3 to 5 seconds.The props are non vented.Would I get a better response if I vent the props and would it be better if the engines spinup faster rather then bog down for a few seconds.When I have a larger load it takes even longer.And what would the cost be to make them vented if it would help.
Mark |
You can vent the Bravo 1 props by drilling holes in them. Sounds like it would help your boat get on plane quicker without bogging down the motors when you try to get on plane. You can drill the holes yourself, keep in mind stainless is an abrasive material and can eat drill bits. It is best to have a drill press if you want to drill the holes yourself.
Start with 5/16" holes and work up from there. Sometimes with the Bravo 1 props we have to go as large as 1" with the vent holes. The charge to drill the holes depends on the size of the hole, typically we charge about $3-5 per holes depending on the the size. Matt |
I have a press.Where are the holes drilled and how many on each prop.I have the 4 blade bravo.
Mark |
| All times are GMT -5. The time now is 01:28 PM. |
