New 2005 XR - can't get on plane
I have a 2001 29 ft, single engine Fountain, with a 575SCi
Just repalced my broken XR drive (2001) with a new 2005 XR drive - old drive had a low water pickup only -- new drive has a combination pickup. Mercury says combination pickup is a faster drive, therefore we all assumed it was more streamlined with better water flow to prop. Boat ran 86 to 87 mph before with a 32" lab'd B1 at 5400 rpm. Before, when coming on plane at 3200 rpm, prop would blow out just after boat nosed over, but when i reduce rpm back to around 3200, prop would re-bite , boat would keep accelerating, and off I go. With the new drive, prop would not re-hook - it just kept slipping no matter what rpm i backed off to - and boat eventually fell back in water So - installed a 1-1/2" space and problem solved but lost way to much speed and rpm, even with a smaller 30" prop - so we installed a 1/2" spacer and with two adults in the boat, it was back to OK with speeds back to 87 mph at 5300+ rpm -- boat acted like it used to getting on plane. This past Saturday, had two adults and 3 small kids in the back and Blow out again -- Had to have kids move up front to get it on plane -- Why the problem with a supposedly more hydrodynamically efficient drive ???? Is it the upper water pickup holes ?? Any suggestions what to try next ?? I am thinking trying a 1 " spacer and then a low water pickup only and see what happens |
Re: New 2005 XR - can't get on plane
Interesting, Keep us posted!
are you sure your original drive was the same ratio as the new drive?? Almost sounds like you had a 1:65, and now you have a 1:50.
DISREGARD.......MISSED THIS LINE...... it was back to OK with speeds back to 87 mph at 5300+ rpm |
| All times are GMT -5. The time now is 03:15 AM. |
