-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Looking for suggestions mirage+ b1 ? (https://www.offshoreonly.com/forums/prop-talk/111486-looking-suggestions-mirage-b1.html)
JP 09-01-2005 12:51 AM
I have a 91 scarab excel 21 ft 3800 lb dry weight single 330/454 Stainless Marine Manifolds and a larger arrester. I currently have a best cruise of 48.2 at 35-3600 and a top end of 62.8 at 46-4700. I currently have a 23 mirage HEAVILY cupped a small amount of pitch added in the middle of the blades and the leading edges slightly thinned and polished. What direction should I go Mirage plus or what I was thinking is a 24 b1 labbed. I know it is a tough question but I and trying to raise criuse and top end. Out the hole is not extremly important. I am going to keep this engine while the budget being saved up for a different engine. Also in the process of trying to tune every last hp I can find in this engine so i believe I will be able to get another 100-200 rpm maybe out of this engine. Almost forgot bravo 1 outdrive 1.5. Any suggestion would be great thanks.
throttleup 09-01-2005 09:05 AM
Re: Looking for suggestions mirage+ b1 ?
Before dialing in your propeller you will need to complete the motor upgrades, the propellers are the last thing you do when dialing in your boat. For top end I would suggest that begin with a Mirage Plus. The 4B Bravo I will be a bit slower on top than the 3B propeller.
Julie
JP 09-01-2005 09:07 PM
The mods I am doing are jetting and timing nothing that is going to be a great increase I am currently at 4650rpm roughly I want to be 46-4800. the most I except is a 100 rpm increase It is real close to correct now I just have to always tinker with things Thank you for any help
throttleup 09-02-2005 08:04 AM
Is your motor the Mag?
Is it carborated or fuel injected?
Julie
JP 09-02-2005 10:41 PM
non mag carbed
