-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Bravo I prop (https://www.offshoreonly.com/forums/prop-talk/112501-bravo-i-prop.html)
estonian 09-16-2005 02:24 AM
Bravo I prop
Hi! I just got new Bravo I 26P prop. Before I had Mirage Plus 25. With Mirage I had max speed 61 mph (4800 RPM, gear ratio 1,63). With Bravo RPM remaned the same, but max speed was 58 mph. I measured the pich of Bravo and found out that it varies from 22-23 (smallest at the centre of the blade). Is it normal, that real pich is so much smaller (should be 26)?
throttleup 09-16-2005 06:38 AM
Re: Bravo I prop
Most of the Mercury props are not the pitch they are marked. The Bravo 1 props are lower than they are marked. As you go to the higher Bravo 1 pitches you will find the difference between the marked pitch and the actual pitch to be greater. It's not unusual for a 36 Bravo 1 to have a pitch of 33, out of the box.
The actual pitch of a stock 26 Bravo 1 should be about 24.5 - 25. Is your prop stock or lab finished?
Matt
estonian 09-16-2005 06:42 AM
Re: Bravo I prop
Thanks for the answer. The prop is stock.
throttleup 09-16-2005 01:05 PM
Re: Bravo I prop
You have about 17% slip at the 4800 at 58 MPH with 1.63 gears. you really should be from 11%-14% slip.
Give us some specifics on your boat, engine and set-up. Maybe we can come up with some suggetions for you.
Julie
Alex17 09-17-2005 04:25 PM
Re: Bravo I prop
What boat is this on?
estonian 09-18-2005 02:15 AM
Re: Bravo I prop
The boat is self-made 23' deep V (28 degrees). Weight is 3000 lbs. Engine is Crusader 350 (270-290 HP). Sterndrive is Volvo Penta 280 (with self-made propshaft to fit MerCruiser props). You can see some pics at www.navis.ee (section "sport"), there are some clickable pics.
Rocko C 10-06-2005 11:05 AM
Re: Bravo I prop
Correct me if I'm wrong...my Baja dealer advised me that when going from a Mirage + to a Bravo I, you're supposed to go down[U] by 1 pitch due to the extra blade or you will lose top end. So estonian should've gone to a 24P Bravo I. Was I incorrectly advised ?
throttleup 10-06-2005 04:14 PM
Re: Bravo I prop
Rocko, you are correct! If you are running at the appropriate RPM then indeed you would need to decrease one inch of pitch to compensate for the drag of the additional blade.
Julie
Rocko C 10-09-2005 10:32 AM
Re: Bravo I prop
Here's a question for you...What is the approximate RPM gain when going from a 28P Bravo I to a 26P ? I have a 28P now and am only turning 4400-4500, do I need a 26P or 24P Bravo I to get to 5000 RPM ? THANK YOU, Rocko C. :confused:
Julie
throttleup 10-10-2005 12:53 PM
Re: Bravo I prop
Each inch of pitch is equal to 200 RPM. So 2 inches of pitch is going to produce a 400 RPM increase.
Julie
