-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Prop rpm for a Velocity 22 (https://www.offshoreonly.com/forums/prop-talk/112848-prop-rpm-velocity-22-a.html)
jdcorbitt3 09-21-2005 08:54 AM
I am going to repower a Velocity 22 with about 400hp. I am interested in knowing what my prop rpm should be. I would like to top out between 75 and 85 mph with a Bravo 1
Thank you,
John
throttleup 09-21-2005 10:20 AM
Re: Prop rpm for a Velocity 22
What is the base motor ie: make and model.
Julie
bbladesprops 09-23-2005 02:55 PM
Obviously the engine configuration is key.
Here is an example.............
5200 engine rpm with a 1.5 gear ratio turning a 28 pitch propeller with 13% slip nets 80mph.
jdcorbitt3 09-26-2005 02:49 AM
I am loking at a Merc 502at 5200rpm or using a Mazda 20b with about 7000 rpm.
bbladesprops. It looks, by your example, that a 28 pitch should be turning 3500 rpm at the shaft. I am assuming 15" diameter.
John
throttleup 09-26-2005 10:24 AM
If it is the mercury 502 then you will need to run at 5000 RPM at WOT. I cannot make a recommendation for the Mazda motor, sorry.
Julie
bbladesprops 09-26-2005 01:25 PM
Yes, with a 1.5 gear ratio @ 5200 the prop would turn 3467 rpm. The Bravo 1's are 15-15.25" diameter even though they are "all advertised as 15.25" Also, the true pitch is aprox. .75"-1" lower than stamped.
Griff 09-26-2005 04:21 PM
What rpm you turn depends on what rpm the engine was designed for.
Change the prop pitch acccordingly to put your rpms in the correct range.
What drive???? A bravo will more than likely not like 7000rpms.
jdcorbitt3 09-27-2005 02:24 AM
With 7000 rpm I will need a 2:1 gear reduction to yield that 3500 prop rpm. Thank you. This is the info I was looking for. I was trying to figure out the prop rpm that most props were most efficient at.
John
mmwalters 09-28-2005 09:44 AM
John
Save yourself some heartache a mazda 20d will never make enough torque to push your boat the way you hope. I know it will make plenty of HP but it will not work well in a boat. Stick with the BB chevy
offshorebankin 10-05-2005 05:10 PM
guessing 28 bravo
