-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Adding a Whipple, what prop to try??? (https://www.offshoreonly.com/forums/prop-talk/115115-adding-whipple-what-prop-try.html)
Pure Energy 10-25-2005 06:03 PM
I have a 30' Superboat Y2K. Currently has 600 hp, bravo xr drive, left hand rotation. Spins a 28 4 blade bravo 1 @ 5300 rpm @ 81 mph. I tried a 30 bravo 1 and got 5100 rpm @ 77.5 mph. I've also tried a hydro px-5 26p and got 5500 rpm @ 74 mph.The hull is stepped, X-dim is 1.5" higher than the factory, that's all I know. Dry weight is approx 4500 lbs.
Dustin @ Whipple estimates 800 hp. Any thoughts as to what props to try??
zt260 10-25-2005 07:24 PM
Re: Adding a Whipple, what prop to try???
You should need to add about 4" of pitch. You may want to try a 5 blade and lower that slip percentage. It's pretty high right now.
throttleup 10-26-2005 09:47 AM
What is your wet weight?
What RPM is the peak HP produced?
Julie
Pure Energy 10-26-2005 10:34 AM
Julie
Dry is 4500 + 100 gal fuel tank, light gear, passengers max @ 500-600 lbs.
Peak hp is @ 5700 rpm
throttleup 10-26-2005 12:43 PM
Well, I would anticipate, from youyr initial post that you will run about 91-93 MPH with the new power. So that being said you will need to run a 30P propeller to achieve this speed. I wuold baseline the propellers you have and post results or feel free to call me with them. Safe Testing.
Julie
bbladesprops 10-26-2005 04:09 PM
Adding 200 hp is worth a addition of a couple inches of pitch or 400 rpm. You were were able to turn the 28 at 5300 which means it will be a perfect prop to test with.
Pure Energy 10-27-2005 07:30 PM
Thanks for the help! I was thinking I would be close with the 30p.
