Never mind...I just opened the attachment...Thanks
502,
Still testing props, and spacers. About to upgrade my motor to aprox 750 hp. Just thought my testing and data, may be of some assistance. Chris |
Originally Posted by CB-BLR
(Post 2772124)
502 stang,
After re-reading your post... you definately need to lower your outdrive via spacers. The fact that it takes a 6-blade to even marginally hook up, along with the lack of bow lift says you need to go lower. I have done spacer testing recently, with my prop shaft centerline starting at 3.5 inches below the keel. In half inch increments, I lowered the outdrive using spacers. Every time I lowered it, I picked up speed. Attached is the spreadsheet I made. Hope this helps, Chris |
It does help...Thanks for the info Chris!!!!!!!
502,
The original prop delivered with the boat was a 28 Maximus. Boat went 77 mph with 16% slip. After talking to Brett at BBlades this morning, I will try going up in 1/2 increments while testing the Herrings. My boat is in the Portland boat show right now, and then will be in the Seattle boat show, so there is a delay in testing untill Febuary. You can give me a call if you want, and I will further discuss my findings. Chris 206-235-4545 |
| All times are GMT -5. The time now is 07:48 AM. |
