-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   SSM II and SSMIII props? ASD? too (https://www.offshoreonly.com/forums/prop-talk/118788-ssm-ii-ssmiii-props-asd-too.html)
IRONMAN 12-20-2005 09:45 AM
1. Will SSM3 props fit the SSM2?
2. Are the SSM4's the same also?
3. Has anyone tried an ASD6 rolla round ear on any of the above drives? It will fit the SSM2.
Thanks, Chris
bbladesprops 12-20-2005 05:28 PM
Re: SSM II and SSMIII props? ASD? too
The SSM II drive uses a 1 3/8" OD prop shaft and can only accept 4" hub lengths with 19 splines. Your key is the 4" hub. In "the day" SSM III drives came with 4" and then a longer 6" hub. The 4" can be adapted to the 6" prop shaft, but not the other way around.
